How to: Change the rings/delay before going to voicemail!
02-10-2020 12:27 AM - edited 01-05-2022 10:35 AM
When I was with Rogers previously, they would forward a call to voicemail after 20 seconds. I noticed with Public Mobile, calls forward to voicemail after 25 seconds. Did not appear configurable, until I stumbled upon how in some old GSM documentation, and it works with Public Mobile! It's as easy as adding two stars and the number of seconds to the usual manual *61 command.
First of all, note your current voicemail number is configured for "Conditional call forwarding when no reply" or "unanswered" for use in the new setting:
Dial *#61#
In my case, I get this response:
Result of dialing *#61#
Now, you can set any delay in 5 second increments up to 30 seconds, for example:
dial *61*3065804001**15#
Result of dialing *61*3065804001**15#
Great, so its now set. To confirm that your setting was committed, use the query command, and you should see the desired number of seconds, along with the target phone number:
dial *#61#
Result of dialing *#61# after new settings configured
That's it! Now my phone won't ring nearly as long if I'm not there to answer it right away. This is equivalent to about 3 rings.
If you screw up your conditional call forward setting, you can quickly "undo" everything and revert them to Public Mobile defaults:
##61# - Revert only unanswered conditional call forward to your regular voicemail deposit #, and 25 seconds.
##004# revert all three conditional call forward settings (Busy/Declined,no answer/no reply,unreachable)
Cheers! - N.
PS: Now, only if the other method documented in the GSM for forwarding SMS messages would work.. It appears the GSM standard defined a way, but virtually no carrier actually supports it...
( * * 21 * telephone number*service number #) - service # being 16 for SMS...
Service
02-10-2020 07:28 AM
@Nezgar More good work. I'm glad you're a lot more curious about how this stuff works than me. You're a god send to the non phone fiddlers here making it easy to type our query in the search bar and have the answer pop up. Thanks!
02-10-2020 12:39 AM
Thanks. Thought so.
02-10-2020 12:36 AM - edited 02-10-2020 12:39 AM
@Anonymous wrote:There's a guy that's been asking about making it just keep ringing for much longer than 30 seconds. I don't think there's a way. Would you agree?
Indeed, 30 seconds, is the max, and cannot be completely deprovisioned with ##61#. (With Public Mobile, this just sets the default voicemail # again, at 25 seconds)
02-10-2020 12:35 AM
@Anonymous I wonder if you change the 15 to 180...if it would ring for 3 minutes?
02-10-2020 12:31 AM
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
