How much slower is the unlimited data speeds after the 50GB plan is over?
Magnetisms
I am a heavy data user, and I would like to know how slow is the unlimited data after the 50 gigabytes of data has been used? I am using the 34$/month plan.
@Handy1 wrote:
@Magnetisms  once the 50GB is used up you will be throttled to 512KBps and your account will display like  this
The speed gets reduced to 512Kbps.  512KBps is actually 4Mbps.
@BKNS27 wrote:
@Magnetisms
Once you used up all your 50gb of data. Data will stop working and you need to purchase extra data add-on or connect to public wifi.
This isn't correct. The customer has specificly indicated that a plan with unlimited data is being subsribed to.  The data will not stop working.
will13am
@Magnetisms , the unlimited data is throttled to 512 kbps, which is 0.5 mbps.  The speed limit on 5G data is 250 mbps.  So, the theoretical difference is 500x.
Magnetisms
Sorry, but I believe you are mistaken. It says under the plan details that there is unlimited data at reduced speeds? How slow would those be?
Thanks for your fast response! ❤️
@Magnetisms
