How much payment is required?
Amz1
Hi,
How much do I need to pay for next month's service considering the credit on my account? I cannot login to my account to check as my access is unauthorised for 1 year.
Thank you,
Amit
so, are you one of those that need to pay by voucher for a year?  if you are, you will need PM to apply the voucher and you cannot do it yourself via *611, right? or you can using *611 to load the voucher?
Amz1
Thank you everyone - much appreciated
AK32
Hey, this is a public forum so we cannot give you specifics to your account.  If you have a credit on your account, that amount will be used first and you will owe the rest.  If you cant log in for whatever reason, you can message a PM customer service agent using this link:
TheSterlinger
@Amz1
If you can try sending message to CS_agent asking how much is the bill.
To check your messages click here
You can also call *611 and it will tell you.
slusagm
not sure if you can call *611 on your phone and check
if *611 does not provide you the answer, you will need to message PM
eddieO
@Amz1 this is a public community forum so no one here will have access to your account. You will need to connect with a support agent.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
