02-18-2024 01:21 PM
02-18-2024 01:40 PM
02-18-2024 01:39 PM - edited 02-18-2024 01:39 PM
Look at the top right corner of this page.
02-18-2024 01:38 PM
About an hour now it was fast when i did my wife
02-18-2024 01:37 PM
I am on with fonus now wonder if that would make a difference. What is that phone number.
02-18-2024 01:25 PM
@Superbiker60 how long have you waited?? usually quite fast, within an hour or two. You just need to reply YES within 90 minutes
02-18-2024 01:24 PM
Hey @Superbiker60
You should get it within 90 minutes. Just make sure your old SIM card from the other provider is still in there to say yes. If you're still having issues, I can help you by sending you a phone number to contact to re initiate the port. Top right corner mail box.
