3 hours ago
Hi,
How long we able to stay in USA with a Canada USA plan before you close the account?
Scenario passing 5 months in USA, fine with my contract
Thanks
2 hours ago
keep your current Cdn / US plan active and you can stay there for as long as you want. There's no set limit with PM.
2 hours ago
Fizz Mobile, Freedom Mobile have a limit on the numbers of days you roaming, Fizz is 3 months and with FM you are able to play with wifi calling to reset the timer near every days.
2 hours ago
there's no time limit...just make sure to re-fund your plan every 30 days . If you have a valid credit / debit card on file set to Autopay...you're good to go.
2 hours ago
@Linuxmtl1 wrote:How long we able to stay in USA with a Canada USA plan before you close the account?
There is no published limit.
