12-25-2021 02:56 PM - edited 01-04-2022 04:48 AM
How much of my plans call/texts/data still work while in US without buying US addons?
Can I still receive calls and texts?
12-26-2021 12:52 AM
@BEST Yes could still use your service without paying for anything in addition. For example, if your planning to be in Niagara Falls NY just make sure to turn off roaming. From my own experience if your near a Canadian border expect to get bars from local Telus tower as long as its within range. This will work even if your in the US. This works for any carrier. Worked great for me as I recall trying it with Freedom between years of 2015-2018.
For trips where you are going further into the US I would not recommend using a PM addon. For the price they charge you can just buy a T-Mobile Prepaid sim for the same price and it'll include unlimited data; some travel sims like this don't even require you to create an account.
To prepare for a trip; I recommend buying the sim from Amazon if you want to be prepared in advance. Most grocery stores in US also sell them. For example, Wegmans and Walmart.
This part is optional. What I do for myself, I have an extra smartphone for travel purposes. I would activate airplane mode on my main device and insert the travel sim in the secondary device.
12-25-2021 05:46 PM
This is the big disadvantage of 90 day plans is they don't work well for suspension on long absences from home. Your $27 in rewards s that $9/30 days=$27/90days? And you really want to keep your unthrottled 4G LTE data? If so your best bet is a mint mobile plan in the US with call forwarding your pm number to fongo. This works better with a dual SIM phone but can still work if you only have a single sim phone too but you would need to put your pm sim card in a spare phone or pop it back in your phone every once in awhile to check for text messages.
With mint mobile's cheapest plan $15/4gb per 30 days (about $19 cdn) and your pm plan after rewards averaging $31 per 30 days you will be looking at about $50/30 days for full services in the US (unlimited US and to Canada and Mexico, texts and 4gb of 4G LTE or 5G data) and your incoming pm calls to fongo on your phone and your incoming pm texts.
12-25-2021 05:29 PM - edited 12-25-2021 05:30 PM
@BeachNBeer wrote:@BEST What can work without an add-on - You likely would receive incoming text as some have reported this. That's it!
That's not even YMMV. The incoming text messgaes while you're in the US is supposed to work even without a roaming add-on. Although it did previously work, this was made official at the same time Public Mobile stated that the glitch that caused people to stop receiving incoming text messages after returned to Canada was fixed.
12-25-2021 05:20 PM
Oh, I missed that. If @BEST going US long, you can move to Fongo. There is a one time charge to port the number in, I think $25. But as I said Fongo text is not free to send. You need to pay $10 / 3 months for outgoing text.
I believe you can port into TextNow, too but I am not sure the charge.
With the charge and the trouble to port it out when you back into Canada, it really depends on how long you are going away.
12-25-2021 05:13 PM
If you want a long term plan while in the US then you might consider using mintmobile.com.
12-25-2021 04:54 PM - edited 12-25-2021 05:08 PM
Hi @BEST ,
Try TextNow instead of Fongo. They are both FREE and you can get a Canadian number. Free to make calls and receive calls. But Fongo charges you to send out text and charge you to call US number. Textnow is FREE for sending text and calling BOTH Canadian and US numbers
What you need to do before you trip to US, Forward All calls to your Textnow phone number. Then you have to remove your PM SIM. If you leave our PM SIM on the phone and turn on the phone in US, the PM SIM tries to connect to the US network, it won't work as you didn't pay roaming, but it will cancel your forwarding. So, it is best to remove your PM SIM while you are still in Canada
With forwarding turned on to forward to your TextNow number, you will receive calls whenenver you have Wifi (or if you got a US data SIM, it will work whenever you are connected).
12-25-2021 04:36 PM - edited 12-25-2021 04:36 PM
@darlicious wrote:One question....Which plan are you currently on?
@darlicious I am on the $40/12GB 90 days plan with $27 total rewards
How does call forwarding to Fongo work?
12-25-2021 03:47 PM
Options for your account and service....
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels!
Here is some info about US roaming add ons that should help you.....
Happy travels and Stay--Safe!
12-25-2021 03:39 PM
It has been confirmed that you will be able to receive texts in the USA, without any roaming add ons. The problem is unable to send texts, call or use data without any roaming add on.
Q: Will I receive incoming SMS while roaming in the US?
A: Yes, you will receive incoming SMS while you are roaming in the US for free. However, in order to respond to the SMS, you must have a US Roaming add-on which includes the SMS feature.
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming
If your account is suspended more than 90 days, then your account will be closed permanently and number lost.
Here is one way to keep your number while away:
12-25-2021 03:27 PM
@BEST wrote:I would be there at least an year.
Would I be able to switch back to an expired plan later if I switch to the $15 plan now?
I want to keep using my current plan and phone number once I return but it would be a lot of extra cost if nothing in the plan works except ymmv incoming texts.
review
Reactivate a suspended plan (publicmobile.ca)
and buy a local SIM card from there... and for your number with public mobile you do a suspended and pay every 86 days to you save your number.
and click Here link to you know how to Change Your Plan online,
you can choose at your next plan renewal date. To change your plan.
12-25-2021 03:27 PM - edited 12-25-2021 03:28 PM
@BEST You can suspend your account for 90 days at a time. MAKE SURE to set a reminder around 85 days to log into your account, un-suspend, pay then re-suspend for another 90days. It is important to remember that although you can suspend for 90days that you reactivate a few days in advance. (85 to be safe) If it's past 90 days account is closed, deleted and you loose your number. You can switch to lower plan so it's cheaper.
12-25-2021 03:25 PM - edited 12-25-2021 03:27 PM
You can allow your plan to go into a suspended state for up to 90 days, but then you'll have to reactivate it with a minimum $15 plan cycle, after which you can again allow it to go into suspended state for up to another 90 days.
You can repeat the cycle while you're away if you want to retain the account.
12-25-2021 03:23 PM
No services that work while in Canada will work in the USA.
You need to buy a USA roaming add-on to either call text or use data.
These options are available under the plans option in the upper part of this webpage. Remember that these add-ons are only good for 10 days so plan your purchase accordingly.
12-25-2021 03:20 PM
12-25-2021 03:12 PM
HI @BEST , Some people confirmed that you will still receive text when you are in US WITHOUT US Romaing. But just receive, not send. Could be a glitch so YMMV.
How long you are there? you can buy the roaming package , pick the one suits your need. Or, if you are there long time, it is better to get the local prepaid data sim for data access. You still won't receive PM calls. But you can use VoIP app to make calls and give the number to your friend.
12-25-2021 03:07 PM
@BEST wrote:Does plan data and bonus data add-ons only work in Canada?
for the gifts holidays only working in Canada.
review Add-ons visit Here link...
12-25-2021 03:06 PM
@BEST That is correct. Plan data and bonus data from gift's only work in Canada.
12-25-2021 03:05 PM
12-25-2021 03:04 PM - edited 12-25-2021 03:05 PM
12-25-2021 03:04 PM
12-25-2021 03:02 PM - edited 12-25-2021 03:04 PM
I want to know what can work without buying these add-ons, I am looking to still receive OTP messages to my number during an extended stay in USA
12-25-2021 03:02 PM - edited 12-25-2021 03:02 PM
@BEST Some report that you would receive text without a USA add-on. Can't reply!. You would need a add-on. Add-ons are for 10 days and start from purchase. So don't buy days before you go.
Alternatively another option is you could download TEXTNOW app. Canadian number in your area that allows you to make Free calls to Canada/USA and text over Wi-Fi. Has caller ID and voicemail if you're not online.
12-25-2021 02:59 PM - edited 12-25-2021 02:59 PM
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
when you visit U.S. and then Purchase it,
sign in to Self-Serve, to review your account,
How To Purchase Add-Ons Using Your Self-Serve Account
Follow these steps:
after purchase successful you have to do Rebooting your phone
what is meant by rebooting the device turn off and turn it back on.
review of Add-ons visit Here link...
make sure enable roaming on,
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, to do it for you..
