How do I use my 3G speed data on my cell phone?
dsouzac
Hello,
Could you please tell me:
Do I turn ON the data symbol of my cell phone in order for me to use my 250 MB 3G speed data?
Please send me a reply.
12 REPLIES 12
srlawren
@dsouzac wrote:
Thank you so much for your help.
@dsouzac did you get all the info you needed?  Everything good now?
cavemantoronto
@dsouzac wrote:
Hello,
You need to turn on data is the settings to use it.  Also, turn off background data tasks or your 250MB could be all gone when you haven't tried to use it.
dsouzac
opendoor
Hi friend try this APN settings. It should work.
Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Click here
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC:http://aliasredirect.net/proxy/mb/mmsc
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
popping
@dsouzac wrote:
I have LG G5 cell phone.
1.  For LG G5, you need to do a network reset after switching provider before your data working again.
2.  Enable mobile data.
3.  Configure APN using the following link as a guide.  Double check on your spelling.
https://apn-canada.gishan.net/en/apn/public-mobile
4.  Restart your phone and test your data.
Tony8
Hi, If your "Data" button is on, and you re-started your phone, it should work. You will see your network icon on the top of your phone change from just "Signal bars" to "3G" or "LTE". Open your browser app and see if it works. Turn off your Wifi if you are at home or the internet connection will default to Wifi. With only 250mb you will want to turn it off , when not using it, or app apdates will use it up quickly. 🙂  I hope you got it working. If not you may have to fix the APN settings.
@dsouzac  you may not set up the APN. Here is the link:
https://www.publicmobile.ca/en/on/get-help/articles/what-you-should-do-after-activating
Jessica_T
@dsouzac  Once you enabled data, is it working? Likely right away it will work. If not, let us know. If you have not used data before your 250mb may get used up for updates without you even knowing. That you can log into self serve and see if your data add-on is missing which means it got used up.
dsouzac
Jessica_T
@dsouzac wrote:
Hello,
@dsouzac  What model of phone do you have? You may have to also configure your APN settings once data is enabled.
hairbag1
@dsouzac wrote:
Hello,
Go into Settings and turn on Data. Depending on which phone you have.
Tiprix
Yes, you would need to click on the data symbol in order for your phone to use data.
