01-08-2019 08:22 PM - edited 01-05-2022 03:00 AM
I'm not going to check it anyway.. I hope I can just turn it off. tyia
01-09-2019 02:21 PM - edited 01-09-2019 02:21 PM
@RobertQc appreciated. 🙂 Not a biggie, but probably a good practice to follow. EDIT: snippets here and there are fine of course. I do this sometimes to call out certain parts of a posting that I'm linking to.
01-09-2019 02:03 PM
@srlawren wrote:@RobertQc thanks for providing this info for @itsmeinhere. In the future, could I plese ask that you just post the link to any of my posts rather than a wholesale copy-and-paste of the content? I do appreciate that you attributed it to me and provided the link, but I'd rather keep duplication to a minimum. For example, if the procedure changes in the future and I update that post you linked to, then anyone following links to it will get the most recent version of the info.
@srlawrenSure, Good call. I edited the post above to reflect that I agree with this.
01-09-2019 01:58 PM
01-08-2019 08:23 PM - edited 01-09-2019 02:02 PM
@itsmeinhere wrote:I'm not going to check it anyway.. I hope I can just turn it off. tyia
Apparently, this is the way to do it.
Call your PM telephone number from any touch tone phone. Let it ring through to the voicemail prompt. While the answer prompt is running, hit "*" (asterisk). It'll pause a bit, then ask for your password. Enter the password that you have established for voicemail.
Once you're in the voicemail system,,,
Choose Greetings (3), then navigate to the "Extended Absence Greeting" (EAG) sub-option, then record anything you like (eg. "Voicemail not initialized" or "Text me if you want a response" or "You have reached a data plan only subscriber. Sorry", then choose option "5" -- which will NOT allow callers to leave a message after hearing the EAG.
This effectively disables VM messages AND helps guide those that may call you.
- Thanks to @s2scotty
You can also follow this great guide from @srlawren https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
