How do I switch from a sim
Badly66
How do I switch from a SIM card to a eSIM on a pixel 4
hi @Badly66 then just submit ticket with CS agent by direct message
Badly66
Can’t login in forgot email and credit card
@hTideGnow wrote:
HI @will13am
so, it is free to get a new esim now?  According to the link you sent, it said "When you request a new eSIM through the usual process, we automatically identify you as an existing eSIM user and waive the replacement fee. "
I can't confirm this with personal experience but if the help article says so, it must be so.  If not, there is a dispute mechanism in place to make it so.
HI @will13am
will13am
@Badly66 , this help article explained how to switch from p-SIM to e-SIM.
https://www.publicmobile.ca/en/on/get-help/articles/get-a-sim-card
hairbag1
@Badly66
just download the free PM app, log in to your PM account and buy the esim. Make sure you're aware that esim is only used 1 time. If you change phones...you need a new esim whereas hard sim can just be re-used.
sp
