01-12-2023 11:54 AM
I am inquiring on how to get my invoices sent to my email or have access to them?
01-12-2023 12:35 PM
HI @tessaducharme10 it takes long for PM to prepare the invoices. So, order couple months at a time from CS agent
Also, the invoices are good for tax purpose, but if you are using it as a address proof, it is not good for that. PM is a prepaid provider and does not validate your address and identity when joined, many places will not take PM invoices as address proofs
01-12-2023 12:00 PM - edited 01-12-2023 12:01 PM
Do you need it for tax purposes? You can download the last 12 months of your payment history. Going forward consider paying manually just before renewal and you will be offered the ability to download your invoice/reciept. It will contain all of the necessary info required for employer or business reimbursement or for tax filing purposes. Past invoices have to be requested from customer support and take up to 30 days to be recieved by email. Use the links as provided by @softech above.
Edit:
Here's an example....
01-12-2023 11:58 AM
You will have to contact agent to issue you official receipt.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
As explained by @AE_Collector:
01-12-2023 11:57 AM
@tessaducharme10 @You would need to ask support for this
Getting help from agent
Or get help right here in the community
01-12-2023 11:55 AM
@tessaducharme10 for official invoice from PM, please open ticket with support. They might need 2 weeks to prepare that
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
