How do I disable voicemail completely?
tester12
I have been trying to disable my voicemail for so long, I got these instructions from the service person:
To deactivate the voicemail please follow the steps in your online account:
Go to the Price Plans and Services
Select Services
Select Advanced Edit and click Submit
Locate Voice Mail under included features and check the box
Click Submit then Accept.
But there is no Price Plans and Services tab, I have tapped through all menus on both mobile app and desktop website to find the services tab, no luck.
Main issue is that constantly have a notification of new voicemail on my Samsung phone that doesn't go away, and whenever I open it, I have 0 messages in my voicemail. I don't have advanced settings for samsung voicemail in my settings which I have tried before and you can't disable notifications from the phone app, it does have a voicemail notification category but its greyed out. I also tried removing the Samsung phone app package with Universal Android de-bloater but the notification seems to come from within the android's system dialer apk. If you guys have any solutions I am open to anything that works.
12 REPLIES 12
alts63_
I've never used voicemail until today, and only to get ride of the icon for a new message.  No luck so far.  ios
tester12
It never disappeared for me, its been 6 months now, and even after disabling my voice mail completely today, it reappeared, its still on my screen after i swiped it away multiple times after disabling my voicemail
@tester12
I've had that happen on rare occasions...I call them ghost voicemails. There's left over notification from previous deleted messages. They will eventually disappear..I could never figure out how to do it but they do finally go away. If you have no use for voicemail, use suggestions from above to "disable" voicemail.
tester12
Tried that already but it doesnt work too
hi @tester12
again, this is just a phone issue, i think
you can try to clear cache and clear data with the phone app
tester12
I have tried to do it, but OneUI doesn't let you disable notifications from the phone app, I have switched to google phone app and still the notification doesn't go away, I have gone into notification categories voicemail is greyed out, I have tried to uninstall the phone package from the device using adb but the notification is coming from the android's default dialer package which I should not uninstall or it'll cause problems. I have tried everything under the sun.
hi  @tester12
if there is no voicemail, then the notification is just something stuck on the phone from before.  Disable this notification at the device level
tester12
There are no voicemails in the system, I have 0 messages and the notification doesn't go away.
hi @tester12
that notification was from your previous voicemail.  I think what @softech ask you to do is to forward the calls to a random places, it does not even hit your voice mail
call your voicemail once, delete all the voicemail and the notification will be all gone
tester12
I swipe it away and it reappears after 5 seconds
tester12
It did disable my voice mail but I still can't get rid of the notification.
@tester12
there is no formal way to disable voicemail, but there is workaround
To "disable" voicemail, dial: *004*8080000000# on your phone
Then all calls will ring forever or get a fast busy tone instead of forwarded to the voicemail.
To reset it back to defaults, dial ##004#
