How do I create a ticket
Jamaika
I need to create a ticket.  I'm having trouble setting up and getting my old phone number back...accidentally accepted a new one.
Jamaika
okay, thanks.
@Jamaika  Yes usually in 1-2 hours sometimes longer
probably an hour or two.  Would be quicker if you use Chatbot ticket
Jamaika
Thanks.  I've sent a private message...any ideas on how long the response time might be?
@Jamaika  Here’s how
send  a  private message   To CS_Agent
slusagm
Two ways, try both:
  1. Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
  2. or message them using this link:
