08-21-2017 03:22 PM - edited 01-04-2022 02:33 PM
I think I've looked through all of the self-serve but nothing seems to show how much I have left. I think I've used all my data but I'm not sure
03-17-2019 04:24 PM
@Stevenla88 wrote:I think I've looked through all of the self-serve but nothing seems to show how much I have left. I think I've used all my data but I'm not sure
03-10-2019 02:49 PM
@SergeMaslov wrote:It really sucks how Public Mobile designed their portal. Everything says "we don't care". Why not displaying, say, "3000 MB out of 3000 MB used" rather than showing nothing and making the customer wonder and dig in the Community forum??
While I agree with the sentiment... Take this service for what it is, not for what you want it to be. This quirk probably has been around from the time the feature was added.
with Telus' track record of fixing things in Public Mobile's system (or, heaven forbid, setting up a new, modern self serve page from scratch!) I'd want to see other, more crucial problems solved first.
03-10-2019 02:43 PM
Sorry @SergeMaslov that you have to dig...yes that's true when you have finished all your data you can't see it anymore in your first page of your self serve account...it's clear then that you don't have anymore data ...![]()
03-10-2019 02:36 PM
08-21-2017 03:45 PM
Plans Add on -> Data and Addon Usage
If you don't have any row there telling you how much data you have, then its all been used. Else it will show how much is left and beside that an Active tag.
08-21-2017 03:29 PM
Log into the self-serve portal and take a look under My Data & Add-ons. If you do not see anything listed, it means that you've exhausted all of the data from your plan.
If this is the case, you have a couple of different options. You can purchase a data add-on (200 MB for $10 or 1 GB for $30) to cover the gap until your plan renews again. The nice thing with data add-ons is that they don't expire until they're used up, so if you only use 500 MB of the add-on and your plan renews you'd have 500 MB remaining carried over every month and it will sit there until you need it (for example, if you run out of data in your plan again).
Another option depending on how much time you have left before your plan renews would be to contact the moderator team to see about having your plan renewed early. You'll need to have enough funds available on your account for the plan to be renewed.
If you choose to go with the latter route then please click here to send a message to the moderator team and include the following information:
08-21-2017 03:25 PM
Look under Add-ons. If no plans show there, you have indeed used all your data. How long until your next renewal?
