05-27-2023
11:18 PM
05-27-2023
11:21 PM
computergeek541
When I go to the activate link, it stupidly sends me to the app. So I went through the ordeal of signing up for the app. No activate option on the app! Still, every time I go to that link it sends me to the app download page even though I’ve downloaded it already. Then I press open and it leaves me on the homepage, and I don’t see any links there to activate my SIM card.
So then I went online, and the website link is literally just not working!!!!!
05-27-2023 11:38 PM
Yeah I’m on my phone
05-27-2023 11:34 PM
curious, did you use a desktop/laptop or a phone browser to access My Account?
The Change Sim used to have problem if used on phone browser, just want to see if PM fixes it
05-27-2023 11:32 PM
Thank you for the help 🙏 This worked 😄
05-27-2023 11:25 PM - edited 05-28-2023 09:20 AM
@thunderseed the sim card section on your profile page
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
as to the new sim crd number, it's on your card itself
05-27-2023 11:21 PM
Oh thank you, where do I find the SIM card number?
05-27-2023 11:20 PM
@thunderseed If you can’t sign in you will need supports help to sim swap the number for you
Watch for reply top of page to the
Right ( envelope image )
05-27-2023 11:20 PM
05-27-2023 11:19 PM
@thunderseed you don't "activate" your replacement sim card
Instead you change sim card
You login to My Acocunt, go to Profile page , there is a sim card number there, click the Pencil to the right of it to "edit" and update the new sim card number
