2 hours ago
2 hours ago
what error you got ?
if you put in your number here, does it say the number can be ported in into PM
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
or you already submitted porting but got any error after?
give us more details?
2 hours ago - last edited 2 hours ago
@Osquitar should first check to see if the number actually can be transferred to PM
Check to see if # can be ported
