How can I get someone to help me add a prepaid voucher on my phone
03-26-2023 08:11 PM
How come it's not letting me call 611 so I can add a prepaid voucher on my phone
Payment
03-27-2023 08:34 AM
For future reference you may find this post handy to have....
03-26-2023 08:19 PM
Just log into your self serve account, tap the payment tab, and apply the voucher there.
03-26-2023 08:18 PM - edited 03-26-2023 09:09 PM
HI @Parkworker_65 there is still problem with *611 , problem since Thur
But you can keep trying *611 or 1-855-4PUBLIC from any other phone, some people tested and it will connect eventually. So, keep trying and it might work
Of course, if you remember your My Account login, it is quicker to just load the voucher using My Account
03-26-2023 08:14 PM
there has been some problem with *611 at the moment
https://productioncommunity.publicmobile.ca/t5/Announcements/Ongoing-Issue-611/td-p/963252
Try calling 1.855.4PUBLIC from another phone and enter your phone number. This is the same as using *611
Or you can also login to Self Serve My Account to load the voucher
If you have trouble login to My Account, you can also open ticket with PM Support and have them to load the voucher for you. If you use method 1 below, use 4 digits PIN to validate if you have the PIN handy. Or use Method 2 below to open ticket by direct message
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
