How can I activate SIM card instead of eSIM
RinRin32
Hello,
I was not able to activate my eSIM, so I was advised to purchase a physical SIM card, which I did.
Could you please let me know how I can activate it?
I have already paid for the plan.
Thank you.
doucetamanda
thank you I have contacted someone. I appreciate your help
hi @doucetamanda
yes, PM support agent can help
you can submit  ticket by direct message:
But you can try the esim setup again.  Remove all the old sim and disable old esim.  Make sure PM esim is enabled is the only one enabled there.  Reset Network settings and test
if you are really changing back to physical sim, buy a PM sim from Telus or Koodo or Mobile Klink store or Amazon
doucetamanda
same thing happened to me. I am stuck now too. Anyone have options?
slusagm
@RinRin32
check if the eSIM already installed, if so, enable it and give it another try.  Click Reset network settings and test
if you wants to give up eSIM, but a PM sim card from Telus or Koodo or Mobile Klink store or Amazon, then message PM and ask them to help changing it
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Chalupa_Batman
@RinRin32 wrote:
Hello,
Thank you.
Hello @RinRin32
If a CS Agent has advised you to purchase a SIM card, then they should have reset your account so you may enter it yourself. Here's where you enter it. Just log in to your account.
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
@RinRin32  You need get support to help sim swap the number for you just
send  a  private message   To CS_Agent
