2 hours ago
an hour ago - last edited an hour ago
an hour ago
@El_Gato were you being forced to leave PM because of the multiple accounts gaming post from couple days ago? If it was , then PM should have reached out to you and you can reply and ask them to help to port out the number. They cannot just cancel your accounts even you broke any rules here
how are the other accounts? same fate?
2 hours ago
Hello @El_Gato
Of course. It's actually super easy. First, you should check this link to see if the number can actually be ported over to Public Mobile. Here, you can check if the phone number you wish to port is eligible to be ported.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
If the number is indeed portable to Public Mobile, here are the next steps to port over. Please note however, the account on the other provider should be an active one. Although, if it's with Koodo or Telus, there is from what I understand a 30 day window on non active accounts.
To port over, sign in to your account. Then go to PROFILE on your left hand side. Then, on your right hand side the 3rd box from the top labeled My Phone number. The bottom option is Transfer Phone Number and two arrows. Click on the arrows. There you'll see this.
Then simply follow the next steps until you're done. If your number is active at another provider, you will be required to have their SIM card in a phone to accept the porting request.
Good luck.
2 hours ago - last edited 2 hours ago
hi @El_Gato
I think you forgot what you did couple days ago. You said you ported out your account and ask @computergeek541 to delete all your listing (which I think he did as I cannot find the post anymore).
So, why you ask this question after you ported out your account? and why you keep posting after you asked Oracles to delete all your posts?
2 hours ago
@El_Gato I tested PM on a phone I was replacing while my new phone was with my original carrier. Once I had confirmed that PM worked I ported my original number after several months, I think more than 6.
You can choose to transfer your number either during or after activation.
Regardless of when you choose to transfer the phone number, here are some things to remember:
