01-01-2024 01:06 PM
I have submitted a ticket yesterday but have heard nothing.
I am not receiving calls nor do I see any record of calls in the call log.
I have spent time with Apple and done diagnostics and there appears to be no problem with the phone.
I have reset network settings.
Apple told me that I need to re-provision my network/phone/server ??
Shouldn't have to wait so long for help if I can't even receive calls !
01-05-2024 03:01 AM
This problem has NOT been solved.
People in my favourites list, call me and there is no ring and no record of the call I need help right now please
Thanks
01-01-2024 03:42 PM
Could take couple days if holidays
01-01-2024 02:41 PM
support "refreshed the network" and asked me to turn off my phone for 2 minutes and then monitor the situation
since i do receive voicemails from calls that i don't receive or even see in the call log, i am wondering whether this might be related to the live voicemail feature that apple has recently implemented ?
i will just have to see how it goes, thanks !
01-01-2024 02:06 PM
will do
01-01-2024 02:06 PM
HI @frogmeister update us how it turns out
01-01-2024 01:44 PM
right thanks, i have submitted another ticket and await some help, appreciate your help
01-01-2024 01:41 PM - edited 01-01-2024 01:43 PM
@frogmeister we are just customers like you here trying to help . You need to use one of the links-at bottom of this page to submit ticket with support in @hTideGnow reply or in my first reply . To check for the reply if you already submitted ticket @frogmeister
01-01-2024 01:31 PM
been on public for several years, i forget how many but at least 5 i think
01-01-2024 01:22 PM - edited 01-01-2024 01:29 PM
are you a new PM'er...did you just recently port your number in to your new PM account ?
added...check the little envelop icon on top right side of the page. I sent you a number you can call to complete the port process. I think when you initially ported in to PM, it wasn't entirely successful.
01-01-2024 01:12 PM
thanks!
01-01-2024 01:08 PM
HI @frogmeister
submit by direct message agian
please submit a ticket with CS Agent here:
My experience is usually within an hour or two. Since it has been over a day, no hard to send again
01-01-2024 01:07 PM
