How Community Rewards Work
MasonPM
Hello, how are community rewards calculated. Does calculation start beginning of one's pay cycle or start of every month? During the period would one know how much community reward one has achieved? For example would one know if they have reached the maximum $20 rewards?
@MasonPM
Please note that PM is on a 30 days cycle and not monthly. Once you made your payment. 5% of the month will be converted to points. Once you achieved 15 points, you can redeem it for a $15 credit off your next bill.
Points can also be redeemed for Add-on.
To check your current number for of points, just login to your account then click on My Rewards online or on the PM app.
@MasonPM  It a secret formula that only PM knows and are paid out monthly .but I can share that
By participating , reading and helping others with questions . And learning and sharing and good things will happen
ranked chart here
Are you on old legacy rewards or the new point system ??
if old legacy reward you need not do anything the rests will automatically be added to your available funds
if on new point system then once you have 15 points you can redeem $15 off your phone bill from your rewards portal
Re: Community reward
Great
Points rewards portal view catalog
HI @MasonPM
calculate monthly, calendar month.   Usually you will know what you get on the 15th of the following month.
but no one know how much effort needed, it is top secret with PM.  Just keep helping.  But 1 or 2 points are easy, 5, 10 or 15 would means a full time worker here
But keep participate , answer questions that you know.
Here are the general tier of rewards
