SFU coverage
01-06-2024 06:03 PM
Thinking about switching my daughter to PM from Virgin. Can anyone tell me how service is around the SFU campus?
Service
01-06-2024 09:24 PM
01-06-2024 06:24 PM
HI @onechris
Telus has strong coverage in most BC, of course include SU campus. would be good
Also, you are using Virgin already. Virgin (and Bell) share the same Telus and Bell network across Canada. So, if you get good coverage with Virgin now, you will get the same strong coverage with Public Mobile.
Enjoy
01-06-2024 06:11 PM
If we take a look at Public Mobile’s coverage map. It shows 4G/3G around and nearby coverage is 5G.
01-06-2024 06:06 PM - edited 01-06-2024 06:06 PM
@onechris Should be good as those only or bell as PM uses the same towers
check
Cell tower locations
