Hotspot
Shelly5
How do I get personal hotspot working on my phone it says to contact public mobile
10 REPLIES 10
@Shelly5  try reset network settings on your iPhone and then setup the hotspot again.
@Shelly5  - have you updated your carrier settings on your phone?
See that, and other methods to troubleshoot your issue in this article:
https://iphonegeeks.com/how-fix-iphone-xr-hotspot-not-working-issue/#:~:text=Make%20sure%20that%20Pe....
Shelly5
Yes and iPhone xr
@Shelly5   You have data left for this cycle?
And what kind of phone do you have?
self solution removed
Shelly5
It actually tell me to contact public mobile when I try to turn it on
@Shelly5
Are you trying to get friends and family to connect to phone data?
It is a Setting in your phone to allow to connect with the special code on your phone under Cellular>enable Personal Hotspot. Remember this will eat up your data if others connect to your personal hotspot.
@Shelly5  - data on, wifi off.
Google your model on how to hotspot.
Check: how to hotspot - Search (bing.com)
Do you have data left on your plan? Check your self serve account to ensure the data line is still showing.
JL9
What phone do you have?
You wouldn't contact Public Mobile about this. Hotspot works at Public Mobile. This is a device software/settings issue.  I would check if the dun APN type is saved in the settings.
