Honor 400 pro global compatible with Public mobile?
Drunkcow
Curious to see if anyone have Honor 400 pro Global version with Public mobile?
It had Volte support, wondering if it work
Thanks
2 REPLIES 2
slusagm
@Drunkcow it will work but won't be great. Mainly because it lacks VoLTE support with PM system and your voice calls would not work well
You can also confirm here but sometimes an incompatible result might just means it won't work perfectly
https://www.publicmobile.ca/en/get-help/articles/volte
Chalupa_Batman
Honeslty @Drunkcow  you'd be best to enter your IMEI number at the bottom of this page to find out.
