06-08-2021 12:41 PM - edited 01-06-2022 02:50 AM
Hello, How do I hide my phone number from showing up when I am calling?
I need to make a quick call, but I want to hide my number.
I heard that #31# hides my number. Is this legit? What shows up on their phone when I call?
Is there an additional fee when you use #31# to hide your number when calling?
Does this always work with anyone? For example does it cancel out if the receiver has call display when they receive the call?
Thanks in advance!
03-24-2025 06:56 PM
Nezgar
When I use my land line and *67, cell receives call with private. Calling Land to Land will work.
I do get both private and cell # on the land line.
#31#xxxxxxxxx never answer on my land line.
Guess I make all the calls from old land line to both old and new technology. Simple
Thanks for the other hi tech options.
BF2257
03-24-2025 06:43 PM
@BF2257 wrote:When I call #31#plus number from cell to my land line to test, the call does not go through.
That sounds like your land line has some kind of anonymous call blocking feature... #31# is the mobile equivalent of *67 for landlines...
If you really don't want to use your own number (and have it show for the recipients of your calls), maybe consider trying a "burner" number signing up with a VoIP service like TextNow app to make those calls... Or if you want to get more serious sign up for a voip.ms account, and configure a softphone ie MicroSIP to call from your computer, etc...
03-24-2025 06:39 PM
Nezgar
Thanks for the tips. I normally have call display on.
From my cell to another cell the temporarily hide function #31# works fine.
My purpose is to call people who have an incomplete registration - I don't know cell or land line and as a volunteer don't want my number visible when I call.
*67 works Land line to Land line. Is there a standard to hide call cell or landline of calling number and receiving number? I could call on either
THanks
Bob
08-24-2023 10:45 PM
Hi @DonJarby
As per my post above in this same thread:
08-24-2023 07:32 PM
@DonJarby- Yes the first two below are for one-off dialing.
Don't show number = #31#[phone number]
Show number = *31#[phone number]
Check it's current setting = *#31#
If the check says not restricted then the setting in the dialer is set to show it.
08-24-2023 07:14 PM - edited 08-24-2023 07:17 PM
@DonJarby wrote:Hi. I hid my number by using #31#, thinking it would be only for the one call, but now every one I call sees PN. How do I remove it so that contacts can see my phone number? I have a Samsumg Galaxy S20 FE.
#31# is only for that one call. Dialing that code doesn't change the call display setting for your account. In your calling app, there should be a call setting for showing callier ID.
08-24-2023 07:11 PM
Hi. I hid my number by using #31#, thinking it would be only for the one call, but now every one I call sees PN. How do I remove it so that contacts can see my phone number? I have a Samsumg Galaxy S20 FE. Thanks
06-09-2021 04:08 AM
There are ways to do it in the phones menus, but here is the definitive way to set/clear outgoing CID blocking using standard GSM codes with Public Mobile on any phone:
06-08-2021 01:26 PM
Thanks for that. I have edited my post. You learn something new everyday.🤔
06-08-2021 01:11 PM - edited 06-08-2021 01:18 PM
06-08-2021 12:50 PM - edited 06-08-2021 01:24 PM
Here is more info on call blocking from telus...
Edit: As corrected by @Triguy *67 is for landlines only your call will not complete on a mobile phone if you use *67.
To block your phone number before a call, dial #31# before the phone number you call.
To prevent both your name and number from being displayed before a phone call, read more below on Per Call Blocking and how to use it.
Per Call Blocking ( *67) prevents your name and number from being displayed when you call someone who has Call Display. The word "private" will be provided on their display instead. It also prevents the person you have called from using Call Return to identify your number or call you back. This is a free service.
Things to keep in mind when using Per Call Blocking:
To use Per Call Blocking:
If Per Call Blocking isn't working, the most likely reason is that your phone is set to pulse instead of tone. If touch tone is not activated, the system will not recognize * (star) commands. To fix this:
When the following calls are placed, your name and number may be displayed or given out for billing purposes:
Your name and number may also be given out if you:
Display of your name and number is more likely to occur if the call is to a number outside of Alberta or B.C.
06-08-2021 12:48 PM - edited 06-08-2021 01:14 PM
To hidden your number on iPhone:
1. Go to Settings, tap Phone
2. Press Show My Caller ID
3. Use the toggle switch to show or hide your number
or
To hidden your number on Android:
1. Open the Phone app, and open the Menu
2. Select Settings, then Call settings
3. Click on Additional settings, then Caller ID
4. Choose “Hide number” and your number will be hidden
and for that #31# before the phone number and will hides your number , i do used all time but be careful when you make a call to anyone and if the are not answer it don't let go to voicemail if the going to voicemail they will know your number.
Good Luck
06-08-2021 12:46 PM - edited 06-08-2021 12:49 PM
@samcat Yes, #31# is the way to temp. block your number from showing. This is a one time outgoing call display block
Phone settings can also set to hide all outgoing calls, not one time
iPhones have a “show my caller ID” feature in settings if you really want to hide your number, go to Settings>Phone>Show My Caller ID
Some Android phones: Homescreen go to Apps > Settings > My Device.
Open Call > Call Settings > Additional settings > Caller ID.
Select "Hide number".
06-08-2021 12:44 PM
Try *67 before you dial.
