06-25-2023 11:53 AM - last edited on 06-26-2023 01:13 AM by computergeek541
Hi, is a Samsung a03s compatible with a public mobile sim card that I bought many years ago?
06-25-2023 12:01 PM
@hairbag1- lol a perfectly reasonable interpretation 🙂 I took it that he has an old unactivated sim lying around.
06-25-2023 11:58 AM
you're putting an active PM sim into your new phone ? That shouldn't be a problem.
06-25-2023 11:56 AM
@Serenit depends on the model, there are different regional variant
SM-A037U would work., the other one might not as the 3G lacks the 1900 band and you could have trouble with voice
here is the spec for A03S, both models (BOLD are compatible ones)
HSDPA 850 / 900 / 2100 (non - SM-A037U)
HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - SM-A037U
4G bands 1, 3, 5, 7, 8, 20, 28, 38, 40, 41 (non - SM-A037U)
2, 4, 5, 7, 12, 13, 14, 25, 26, 41, 66, 71 - SM-A037U
and these are the bands used by PM
06-25-2023 11:56 AM - edited 06-25-2023 12:00 PM
As long as that sim never got activated then it should be fine. Without looking, as I think about certainly, the phone will be fine. Can you give us the exact model #.
Adding - I don't suppose that sim is from before 2014?
edited before I saw the below.
