02-22-2022 09:12 AM
02-22-2022 10:56 AM
Hi @Lyndzjl and are you are $25 plan? just want to confirm you aware that if you setup Autopay, you will get 500MB bonus data for a total for 1GB data. Check to see if it is enabled 🙂
02-22-2022 10:44 AM
02-22-2022 10:30 AM
THANK YOU!
02-22-2022 10:23 AM
@Lyndzjl I don't think iOS has app that can auto forward tex 😞
So, your choice would be only to frequently login to your son's PM My Account and check the data usage under My Data & Add-Ons. But as advised, there is no overage here. Once the data are used up, the data will cut off until the new cycle starts
02-22-2022 10:14 AM
HI IOS apple phone-thank you
02-22-2022 09:56 AM
there are no overages on PM
02-22-2022 09:28 AM
Thanks @BeachNBeer for adding that.
@Lyndzjl Yup, i missed that you want the text on your phone. No , there is no such service with PM. You can try monitor via Self-serve My Account. Or the only thing I can think of is to install some text forwarding app. Are you on iOS or Android?
02-22-2022 09:25 AM
@softech I didn't mention the text. As the OP is asking about receiving a notification to them for their sons phone. The son would get the notification 75%, etc on their phone but the OP (Mom or Dad) want a text.
02-22-2022 09:22 AM
@Lyndzjl PM is running on no surprise billing, data would get cut off once the data allowance are all used up. Also, PM would send you text information you about that as well
You can also set some app on your device to monitor the usage. But PM is running on 30 days cycle, so, you need to setup something that can auto reset after 30 days and not monthly. Here are some recommended app
Android: Data Counter Widget, Data Witness PM
iOS: My Data Manager
02-22-2022 09:16 AM
@Lyndzjl No. However you never have to worry about overcharges. You pay in advance for your package. If the package includes 500mb. Once the data is all used up then it stops completely. Then you're options are to buy an add-on for more data, change to a higher plan and pay immediately or contact support to renew plan early and pay or just wait till your renewal date for more data.
There are never overcharges with Public Mobile.
