Help
Lynne
Hello how come when I go to get the 40$plan with 4G it's not showing up any more but the deal was till the 20th I don't want to get the 120 just to find out I can't get the right deal.
@Lynne It should work with any unactivated PM SIM. You will know as soon as you try to activate it.
If you need a new SIM check out this post:
http://productioncommunity.publicmobile.ca/t5/Discussions/People-Who-Need-Sim-Cards/m-p/97032
neilselden
You will need a new SIM, unless your old SIM was associated to an account that expired less than 90 days ago.
Lynne
Cool will this work for someone who has an old sim from before or does it have to be all new Sim cards?
marissa19
It might be that your looking on  'get started' page which is now showing full price, but if you go to activate your SIM and sign up for a plan the discount should still be available and show you the proper amount there!
Luddite
The plan no longer shows because it is only available when you are activating a SIM, or log into your PM account.
Do you need a SIM?
neilselden
It is available when you sign up or when you want to change plans.
Hope this helps,
Neil
