Help
10-23-2022 10:22 AM
10-23-2022 11:59 AM
@Tonypmontague If none of the suggestions worked to regain access to your account open a trouble ticket:
click on https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question in SIMon. Follow / invent the prompts until you reach the Contact Us button, click on it and a Submit Ticket button should appear. To confirm that your ticket has been submitted, check the SEND box in your private messages; click on the small envelope next to your avatar at the top right of your screen.
If you have problems submitting a ticket, you can also send a private message to the CSAs. Click: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-23-2022 11:08 AM
Please explain what’s happening with some details. Thanks
10-23-2022 10:37 AM
Hi @Tonypmontague if you remember your 4 digits PIN, try calling *611 and pay that way first
Of course, you am also buy voucher and load via *611 without PIN
10-23-2022 10:31 AM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
10-23-2022 10:28 AM - edited 10-23-2022 10:29 AM
@Tonypmontague Hello try clearing your cache and cookies or try a different browser in private or incognito mode reboot your device and try to sign in again
