07-03-2022 07:46 PM
07-03-2022 10:12 PM - edited 07-03-2022 10:13 PM
Contact customer support as suggested. There have been several reports of the payment system not accepting voucher payments which are normally very reliable and easy to load onto your account via 611. The CSA can check validity and load the voucher onto your account.
For future reference you may find this post and the link to the Voucher Catalogue contained within helpful....
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
07-03-2022 08:25 PM
It's the same place that you mentioned "online" before.
07-03-2022 08:20 PM
@Jenny1974 My Account is Self Serve portal:
https://selfserve.publicmobile.ca/
if you find trouble logging on or trouble opening ticket using Chatbot, just use Method 2 above, Direct Message Support with that link
07-03-2022 08:17 PM
I am very new my second month only. Where is my account?
07-03-2022 07:58 PM
@Jenny1974 no worry, you won't loss your money
Since it has been couple days, open ticket with PM Support and they will sort it out fir you
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-03-2022 07:57 PM - edited 07-03-2022 07:58 PM
you may need to contact a cs agent they can input it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
07-03-2022 07:55 PM
07-03-2022 07:55 PM
Also the first time I wasn’t sure I did it right online first. Not knowing what I was doing then I tried to go to star *611 and now it’s saying somethings wrong with it. I can’t afford to lose this money that I put on it.
07-03-2022 07:54 PM
We tried to get this the day that we got a June 30. Unfortunately nothing has come through since we purchased
07-03-2022 07:50 PM
@Jenny1974 you got error trying to load the voucher? what error message? you tried to load on both My Account and *611?
where you got the voucher from? Vouchers from some stores might need to wait 24 hours before it can be used. Has it been 24 hours since purchase?
07-03-2022 07:49 PM
@Jenny1974 some vouchers take up to 24 hours to activate did you try *611 on your phone?
07-03-2022 07:47 PM
Need help with my voucher pin
