Help with phone unable to all out
Bspc1950
Can’t call-out with phone
Chalupa_Batman
Hi @Bspc1950
A few questions to help figure out what's happening here.
Do you see the Public Mobile name at the top of your phone?
Which plan do you have?
Have you logged in to see if your account is active? ( in other words, did your last invoice get paid)
Let us help you figure this out before you go to a CS Agent. We may be able to solve it for you.
@Bspc1950  You happen to be on the $15 plan , you sure you have mins left
HI @Bspc1950
new account or old account ?
Try to reboot the phone first, check if the phone actually connected to PM network.  Then try to make calls
If still unable to do so, try Reset all networks.  You can also try your sim card in another phone to rule out device problem
Last, if you cannot get it fixed,  submit a ticket with CS agent:
Do the other portions of your Public Mobile service work?  First, let's try the obvious things (that you might have already tried) by restarting your device. Also, if you're not already doing this, try dialing a 1 before the area code when attempting to make your next call.
