Help setting up voicemail
Dake
Hi just joined and can’t get voice mail to work , I tried to hold the number 1 down and it gives me an error. Is there anyone who could help me with this? Thanks , Andrew
1 REPLY 1
hi @Dake try to reboot your phone couple time (with 5 mins in between) and the voicemail number should got pushed down
if not, go to dial, settings, look for Voicemail number and manually enter the number
just go to this post and pick one number out of it:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
