Help - Rarely Use Data, but shows 90% Used
bonsai3339
Any insights appreciated.
I rarely use cellular except when no wifi or when using my iPhone's GPS.
So I I knew it didn't make sense when I received a text early December saying 90-95% of my data was used up.
But since I received the Happy Holidays extra Gig of data before I had a chance to contact PM, I figured I wouldn't bother.
Then a few days ago I get the message again, saying I'm 90% used up.
Has someone 'hijacked' my data?
Or? Is there a setting on my phone that I need to change?
My Settings typically are:
Cellular Data - on
Cellular Data Options - Enable LTE - on
Cellular Data Options - Data Roaming - on
At the moment I have Cellular Data turned off as I am afraid just by having it on it's being used up.
Thanks for help!
10 REPLIES 10
@bonsai3339 wrote:
Thank you Triguy. I hope this solves the problem: I have a ticket in for a moderator just in case 🙂
  • @bonsai3339  Excellent advice from @Triguy  and good that you have a ticket submitted with the moderators. Go thru the data usage with your apps to see if it matches with the usage on your account. There was an issue when the holiday gifts were first given out where the system was recording data usage even when customers were on WiFi only. As suggested...i have my data saver on, data tracker enabled and I reset it every month that does not have 30 days. I also turn off fore ground and background data usage on almost all apps that allow me to do so.
bonsai3339
Am still waiting on the moderators to get back to me as I want to ensure everything has been looked into. I've followed all the advice here and super appreciate each of you for providing it. If I am given new information I will post it here.
Thanks again all of you wonderful people!
bonsai3339
Thanks TEJ20. I appreciate the suggestion.
bonsai3339
Thanks wetcoaster. Mine is off but I appreciate the suggestion!
bonsai3339
bonsai3339
Thank you swimswam. I hope this solves the problem: I have a ticket in for a moderator just in case 🙂
TEJ20
check your data usage in setting
In addition to the above: turn WiFi assist off. That function uses data even if you are on WiFi if the phone seems the connection strength too weak (whatever that the trigger is for that)
Triguy
Check your settings to make that you don't have automatic updates for apps.  Also turn off GPS.
https://www.publicmobile.ca/en/on/get-help/articles/managing-your-data-usage
swimswam
Since you have an iPhone I would recommend going to you iPhone 'Settings' then open up 'Cellular' options, scroll down and turn off data use for any apps you don't want to use your cellular data with. Some apps do auto updates or are just running in the back ground using data.
