12-14-2019 01:45 PM - edited 01-05-2022 08:32 AM
My phone isn’t working I have the number I put in my email an I have to keep doing it
12-15-2019 09:47 PM
Which phone you using, is it unlocked and is it compatible with PM?
12-15-2019 07:51 AM
Is this a new phone? If not, did your service work before you popped your sim into your new phone?
Is this a new account activation?
Lots of questions ... Need more clarification.
12-14-2019 02:58 PM
@Kaylacourtney wrote:My phone isn’t working I have the number I put in my email an I have to keep doing it
We need more info.
Is your phone showing "Public Mobile" on the notification bar at the top?
If yes, can you call out and receive incoming calls?
If no, we need more info.
12-14-2019 02:43 PM - edited 12-14-2019 02:45 PM
@Kaylacourtney If you can make/receive calls and send/receive texts then your plan is working. What you are describing although not very clearly sounds like a configuration issue with your email 2FA.
If you just activated with PM and ported your number,w 48 hours and 2FA should start working again.
12-14-2019 02:17 PM
Yeah, you DEFINITELY need to provide more clarity if you want some help..... other than your phone not working, I have no idea what you're talking about a number you put in your email, and you have to "keep doing" what?
12-14-2019 02:14 PM
Are you a new sign up? Did the phone ever work at Public?
12-14-2019 01:47 PM - edited 04-05-2020 01:25 AM
Stay safe
