Hello
11-25-2019 05:11 PM - edited 01-05-2022 08:08 AM
11-25-2019 06:57 PM
@vladbryn1974If you are using an Android phone, make sure your APN setting is correct
11-25-2019 06:39 PM
My plan is 25 dollars, but data don't work
11-25-2019 06:18 PM
@vladbryn1974 All current plans come with data If you have autopay. If you do not have autopay then the $15 plan has none...otherwise 250mb. The $25- 500mb w/autopay 1gb. All others get a 500mb bonus w/autopay. Best value foe a medium data user $40 plan 4,5gb/5gb w/ autopay.
11-25-2019 05:25 PM
Absolutely! And the plans with data are quite generous, when comparing costs with other providers. Should you need more, just purchase a top up!
11-25-2019 05:13 PM
@vladbryn1974You can certainly get data as add on with your plan. or get data included with your plan.. the former is expensive, I would recommend you get a plan with data allotment that meets your needs
