Having trouble with iPhone making calls
Phungq74
Can anyone help me out? I can't seem to call out with my iPhone even though I have unlimited Canada wide calling. It keeps saying I have only a minute left or something like that.
@Phungq74
first, reboot phone and try Reset network settings, then test call by disabling data
if still cannot make calls without data, test the different network mode: Navigate to Settings > Cellular > Cellular Data Options > Voice & Data.  Try 5G On , 5G Auto, 4G (or it might be called LTE), 3G and test
Phungq74
It seems its an iphone issue.  Samsung doesn't have this issue.  I believe its iphone to iphone calls only that is having the issues.  Basically have to have data to make those calls.  Iphones suck...
Dunkman
@Phungq74
Is everything else working fine?  data? texting?  incoming calls?
Might also want to try a network reset of phone (note: this will erase any saved Wifi passwords).
slusagm
it's a common glitch, usually it will clear up itself shortly
try reboot the phone and test.  And test the sim card in another phone if possible
