Having trouble adding funds
Shanimen
Im trying to add funds on my public mobile and it keeps showing a verification code and I'm not getting anything in my emails using the same email I use when I activated this account, please help
9 REPLIES 9
dabr
@Shanimen    Yes, can confirm that you can receive verification code to reset password on a suspended account, however, I did notice that notification icon is absent for SMS, so you need to open the text app in order to view the code if suspended.
@esjliv- Good memory. Yes, dabr and I tested that out a few months ago. The password reset can be sent to text. The account 2FA not...while suspended.
@Shanimen- Are you currently able to login to the account? Where and how is that verification code screen showing up.
The reset password can send to a text instead of email when suspended. After that then the login can only send to email if you have that 2FA option turned on in the account.
Login credentials can also be tested through the chatbot if you're sure you have the right info.
@Shanimen - what verification code are your referring to ? Reset password?
If you are in Suspended status, how long ago did you last have Active services?
When you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device) to see what the status says. Can Public 'find your account'?
If the account is currently in suspended or Active status you can also look into obtaining a voucher to make a payment through 611,  see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
Locations to obtain some vouchers found here: https://publicmobile.ca/en/on/payment-voucher
@cellphoneuser1 wrote:
If you're note supsened, the code can be sent by text.
@cellphoneuser1 If @Shanimen is using the reset password option, I believe other members have proven/tested that if you are in suspended status, you are still able to receive the SMS option. This may have been a few months ago, so perhaps it is still the case.
tagging @dabr to confirm...
@Shanimen a quick way is to get a voucher from Shoppers Drug mart and load the voucher via *611
or have to open ticket with Cs agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
cellphoneuser1
If you're not suspended, the code can be sent by text.
@Shanimen
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611  no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you  still have service and your plan renews today / tomorrow you can ignore this suspended notice
Shanimen
I can't remember my 4 digit pin
hi @Shanimen your account suspended? if not, have the code send to your phone
if there is no such choice, check your spam folder
And if you remember your 4 digits pin, use *611 to pay
