Having phone connection issues
Warde
My account was suspended, a payment was made, however it still does not work. How do I make it work again?
@Warde   I guess you are close.  Power off the phone for a minute.  Reboot and try again.
@Warde wrote:
Yes, I already went through the reactivate plan option. It says my Account Status is Active
@Warde
Status Active - Check.
Do you have any services at all? Calling/texting/Data?
Have you tried the other trouble shooting tips?
Can you try your SIM into another compatible Public Mobile device?
Not sure if you are using a new or new to you phone, even if you are not, check anyway if your phone is blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
If still no service, after other suggestions, I would ask the Moderators to check your account / SIM card.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
Warde
@Warde
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
If still issues, try adding an addition $1 to your Available Funds, then Reboot.
  1. Add Funds to your Plan Amount through SELF SERVE (or by calling 611 if you have a card registered)
  2. Go to “Plan and Add-Ons” TAB
  3. Select "Lost/Stolen Phone" TAB
  4. Select "Suspend Service" BUTTON
  5. Then, Select Resume/Reactivate Service
  6. Reboot your phone.
@Warde  When you are at Self-Serve, do you see the button to Reactivate Current Plan?  click that, then reboot the phone..
