11-08-2019 10:24 PM - edited 01-05-2022 09:41 AM
Hi
justbwondering how to cancel my account and get my money bAck for the last month. I received the SIM cards and set it up and once finding out my number wasn't compatiable the service was no use for me.
11-09-2019 04:33 PM - edited 11-09-2019 04:34 PM
@Raharma6 wrote:Good day Guys,
What is the suspension policy for public Mobile. If I don’t wanna use my phone for 2 months . Can i keep it suspended ??
Once your latest plan expires...you then have 89 days to renew it. At 90 days, your old number goes away for good and you'd need to start over with a new sim and a new account. Best to renew at 80 days or so...in case there's a problem.
Good luck.
11-09-2019 04:26 PM
You can suspend for upto 90 days without payment before the account becomes de-activated, just remove your CC on file, but make sure you pay around day 85-88 to keep the account active.
11-09-2019 04:22 PM
Good day Guys,
11-09-2019 03:50 AM
@jkd7405 wrote:my number wasn't compatiable
Are you trying to port from Koodo Prepaid or PC Mobile Prepaid? If so, it needs to be done manually by the moderators.
You can open a ticket via SIMon the chat bot: https://www.publicmobile.ca/en/bc/get-help
11-09-2019 12:02 AM
@jkd7405 Unfortunately Public does not provide refunds. If you want to cancel just don't renew your plan. Are you saying that your number cannot be ported to Public? If yes, who is the provider is it Bell?
11-08-2019 10:38 PM
Alternatively...just select a new PM number.
11-08-2019 10:28 PM
@jkd7405 , this is a prepaid service, there are no refunds. When you say your number is not compatible, what do you mean by that? Are you saying your phone is not compatible? If you want to move a Canadian number which is running on a different carrier into this service you can do it using the porting process.
11-08-2019 10:26 PM - edited 11-08-2019 10:38 PM
@jkd7405 wrote:Hi
It is a prepaid service and there aren't any refunds. Your number wasn't compatible? Where is your number from? To Cancel you should remove any credit card information you have on file and de-activate the auto-pay feature.
