02-04-2024 09:57 AM
I have been subscribing since January 2022, yet every rewards summary statement I never receive any points. Could someone clarify for me why that would be? Thank you.
02-04-2024 12:20 PM
Sorry, I meant to say I do not receive the 5%.
02-04-2024 11:47 AM
Now I am confused, if you are on the Legacy Rewards. You shouldn’t have receive 5%…you can only be on 1 Rewards system not both.
02-04-2024 11:32 AM
Thank you Chalupa_Batman for the reply. I will definitely take your advice !
02-04-2024 11:30 AM
Perfect. Thank you very much HALIMACS.
02-04-2024 11:21 AM - edited 02-04-2024 11:21 AM
Then you’re on the legacy plan.
Stay on it, it’s the best plan.
If you switch to public points, it’s irreversible and you will save less over time.
02-04-2024 11:19 AM
OK. I think I know what you're talking about now. So, Public Mobile sends out this report once a month that shows how many Public Points it's members have. Sadly, they can't differentiate the difference between members who have Legacy Rewards and Public Points. I too get that email with zero points. I just ignore it because I know I'm on Legacy Rewards. Just a heads up, never ever change over to the new point system. Stay on Legacy Rewards for the rest of your life!!! Also, don't block any text messages or emails just in case there is an offer that you may like. Once again, just ignore that emails.
02-04-2024 11:08 AM
Thank you. Yes, I do receive the 5% discount monthly but no points.
02-04-2024 11:07 AM
Thanks for the reply. I'm not sure as to the exact date I joined.
I think as you describe it, I am on the legacy reward program.
Yes, as you say, occasional emails showing zero balances.
02-04-2024 11:05 AM
Thank you. Yes, my rewards tab shows up just as the one you displayed. As for the exact date in January I joined, I can't be sure.
02-04-2024 10:47 AM
Here's the true question. Which DAY did you join Public Mobile. If you joined before January 25th you should be on the Legacy Rewards system. If you joined after January 25th, you'd be on the new crappy point system. If you download the app, the tabs at the bottom, click on My Rewards and it should show you what rewards you get. Here's what it should look like.
Check it out and let us know.
02-04-2024 10:23 AM - edited 02-04-2024 10:58 AM
did you subscribe before January 25, 2022 or after January 25, 2022?
it’s quite possible you are on the legacy reward program in which case you don’t receive points, you receive rewards based on auto pay status, refer a friend, loyalty, and community help
if you are receiving emails once in a while, which display your points balance, and they show as zero, that’s a glitch that is received by all members whether they are on the old rewards or the public points.
02-04-2024 10:17 AM
@Fmar Are you checking in-the rewards portal ? Check there you should se the points you have earned once you have 15 points you can redeem that for $15 off your phone bill
02-04-2024 10:09 AM - edited 02-04-2024 10:16 AM
You should have received 5% of your monthly payments in points plus 1 point/referral, 1 point for every year your are with PM.
Please keep in mind that the annual point will be received after 1 year plus 1 month so you might have to wait depending when you activated your account/SIM.
This can be confirmed in your account under your Rewards section.
If not, DM a CS_Agent to investigate at:
