11 hours ago - last edited 8 hours ago by computergeek541
Hi there,
I cannot make or receive phone calls.
Also checking my account shows error?
Payment method was confirmed and not the issue.
HELP!
9 hours ago
@Lilli1804, do you have access to another cell phone that you can try inserting your SIM card in to see if it works? Sometimes swapping devices can help to correct settings
9 hours ago
No system issues
9 hours ago
I have opened a ticket but I still cannot use my phone
10 hours ago
HI @Lilli1804
what phone do you have?
check the Telus outage map and see if any system issue in your area
https://www.telus.com/en/bc/outages
and try reboot your phone. Also try your sim card in another phone if possible, that will trigger a refresh on the system and might resolve your problem
10 hours ago
today is first day of the new cycle?
you rebooted the phone? Does data work? Try Reset Network Settings on your phone
