Have SIM but can't register it
01-15-2020 09:44 AM - edited 01-05-2022 09:02 AM
Ordered a SIM from Amazon and tried to activate but its not letting me.
Joining Public
01-15-2020 02:49 PM
Glad you got it working welcome to Public Mobile
01-15-2020 02:48 PM
Working now, thank folks. Great cheap plan for my daughter.
01-15-2020 02:12 PM
Thanks my phone is unlocked (was never locked, bought directly from Apple. Will try again now.
01-15-2020 11:38 AM
@Farley2020 Since it has been a couple of hours I'm assuming it finally worked for you. If not: If you are getting an invalid sim error, it may just be within the activation process. Wait an hour, clear your cache and go into incognito mode if you can and try again. The invalid sim error will likely be gone.
If you are using your phone to activate, it might be best to move to a laptop. Sims are sometimes defective, but it's quite rare.
01-15-2020 11:08 AM
Please make sure if your phone is unlocked, and provide more details such as error messages. Thanks!
01-15-2020 10:02 AM
Hi @Farley2020
When you say it's not letting you, what actually happens at which step?
Are there any error messages?
Thanks
01-15-2020 09:52 AM
@Farley2020 wrote:Ordered a SIM from Amazon and tried to activate but its not letting me.
@Farley2020 If your are getting an Invalid SIM number error as soon as you tried to activate your card (first time) then that card has been previously activated. Make sure you are entering the correct number. If you got an error after trying unsuccessfully to activate your card then you need to wait for an hour for the session lock to clear within the system before you can try again.
01-15-2020 09:51 AM
Are you getting an error message ? Is your phone unlocked ?
01-15-2020 09:49 AM - edited 01-15-2020 09:52 AM
Did you get to the payment part and then it said invalid payment? If you did, and your card was charged, you created an account with PM and your SIM is registered. You need to contact a moderator. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one.
01-15-2020 09:45 AM
Make sure your phone is unlocked.
