HOw to avail the 2GBFiona
rpmotilla
Hi, how do I get the free 2 GB
darlicious
@nflfan92
Did you just get the text? If you got an official pm text it would have been from about two weeks ago. That may be a phishing text.
nflfan92
I got the same text and the link takes you to a down eventbrite website and I can't get any answers from customer service.
darlicious
@rpmotilla
If your phone number and area code are from an Atlantic province you should be eligible for the 2 GB bonus. Sign into your self-serve account using secret / incognito mode. Go to the plans and add-ons page. Scroll down to the bottom. Enter the promo code 2GBFiona. If you are eligible it will give you a green check mark and add the 2 GB Fiona data bonus to your account.
Outdoorsman
@rpmotilla hi did you get the text? are you in the maritimes in the effected areas? if not then you are not eligable
@rpmotilla is your  phone number from the affected province?
login to My Account,  go to Payment & add on page , there is a promotion box and you can enter thr code there
