04-09-2022 11:09 AM - last edited on 04-09-2022 04:50 PM by computergeek541
I need help with my password/security questions. I forgot them and need help changing them.
04-09-2022 12:18 PM
HI @Chantel93 Sound like you tried Forgot password but failed because of the security question? you can change it after you have access to your My Account
But yes, you need the access back first. Open ticket with PM CS Agent. Directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
04-09-2022 12:13 PM
So you clicked on forgot pw are are banking on the questions. Yeah, as stated you will have to connect with an agent and provide other verification info then
04-09-2022 11:14 AM
Contact agent for assistance. Get ready to provide personal info for verification as they ask you for.
Send a private message to the CSA - agent by clicking Here
