HELP Caller ID isn't working
NotUit
I keep receiving "Private Caller" every time someone calls me even with my contacts!
This is really irritating, is there any fix? This started not long ago.
hss
Make sure your caller ID is turned on. If yes, it could be that other person has turned off his caller ID.
geopublic
@NotUit  That sounds like an issue with how your phone is setup. If you try your sim in another phone it will more than likely work properly. Consider resetting your phone if that is the case.
popping
As the receiver of a voice call, you have no control of whether the caller will block the caller's phone number of not.
ChuckYeah
In order to better help you, we need more info about your issue:
What type of phone are you using?
What version of the OS?
Regardless, the first thing I'd do is restart your phone.
