10-30-2022 08:26 AM
I have a grandfathered $40 3g plan with 5gb. I am looking to switch to the new LTE 15 GB plan also at $40. According to plan details, the only difference I see is unlimited talk versus unlimited minutes in the new plan. Are these the same? And are there any other discernible differences between my existing grandfathered plan and the new LTE plans?
Plans
10-30-2022 10:32 AM
Look closely at your current (grandfathered) plan - what exactly is included.
ALL plans above $15 have unlimited calls/SMS in/out. You might have unlimited USA calls if you care for those.
I would say, for the same money you will get Great deal if you switch!!! And if you need USA calls get free voip app having unlimited calls in North America.
10-30-2022 09:37 AM - edited 10-30-2022 09:39 AM
Disregard....
10-30-2022 08:47 AM
@atmmarazzi The only other possible difference could be that now you have unlimited calls to the US included, which is not included anymore.. but with all the free minutes given out over your time here and the better new plan definitely outweighs that..
10-30-2022 08:39 AM
They are the same except the new $40 plan is 4G speed and has a lot more data, 15 GB.
Also if you change your plan right away, you you won't get your rewards applied to your payment this time around so it's best to schedule a future plan change. That way you'll get all your rewards applied.
10-30-2022 08:28 AM - edited 10-30-2022 08:31 AM
@atmmarazzi wrote:I have a grandfathered $40 3g plan with 5gb. I am looking to switch to the new LTE 15 GB plan also at $40. According to plan details, the only difference I see is unlimited talk versus unlimited minutes in the new plan. Are these the same? And are there any other discernible differences between my existing grandfathered plan and the new LTE plans?
Unlimited talk and unlimited minutes is one in the same, @atmmarazzi
On this plan, you'll get unlimited talk and text anywhere in Canada from anywhere in Canada.
You'll also get data at 4G speeds, vs PM's standard offering of a 3G speed.
If you're looking for extra data, it's definitely the plan to switch to, and it may only be available for a limited time, so act fact. If changing plans, be sure to select "Change on renewal" vs "immediate" plan change as you'll not get credited for any time remaining on the current plan if you switch immediately.
