10-24-2020 12:01 PM - edited 01-05-2022 05:19 PM
Is anyone having an issue with calls going straight to voicemail ? I find in the past few days this is happening. We just tested where my husband calls me and it goes straight to voicemail. Any idea why ?
I've tried in different areas of the house as well as outside and 4 out of 5 calls go to voicemail.
01-15-2021 04:18 PM
Glad it worked for you!
I’m an iPhone user and I hope my “smart” phone gets smarter with a new update sometime soon that will make it recognize when 3G is needed or not. I reached out to Apple to make them aware you should do the same for your phone company! They can’t fix what they don’t know!
01-15-2021 04:16 PM
@kb_mv You probably won't notice any difference honestly... I cant tell.
01-15-2021 04:15 PM
01-15-2021 04:14 PM
Thanks, everyone, for your feedback (switch to 3G, only) - the phone now works!!
Because of you, I may just stick with PM, afterall 🙂
Thanks again.
01-15-2021 04:11 PM
Also, you may find that 3G is *faster* than LTE for downloads as PM only throttles LTE to 3mbps. If you have data to spare, others have reported speedtests showing 10+mbps on 3G mode. Latency may be a bit more variable though.
01-15-2021 04:09 PM
@linkr agree I’ve been with public over 2 years. Only started having this issue the past couple months! When I need data and not expecting an important phone call I will change it back to LTE. Now in their defence they do say data is 3G so I suppose getting in LTE is a bonus 🤷🏼♀️
01-15-2021 03:43 PM
Hmm - that may have done it! Unfortunately, LTE is/was much faster - and was working fine, before. Very strange.
01-15-2021 03:22 PM
@Dolphin1
force your phone to 3g! It fixed my issue completely
01-15-2021 02:00 PM
12-04-2020 11:33 PM
@LoreckAvery Motorola Play7
12-04-2020 08:59 PM
@Dolphin1, I am not a techie person, so don't hold that against me! "
I just found out that I can turn my text messages onto dark mode after owning the phone for 3 years!
If one of the following call forwarding settings is enabled, don’t be surprised if your incoming calls land directly into your voicemail: Call rejection or block; Call barring; Forward to voicemail; Obviously, to fix the issue, you need to disable these settings.
12-04-2020 08:57 PM
What phone do you have?
12-04-2020 08:54 PM
Going thru this currently for a couple months (that I’m aware of) what phone do you have? I have an iPhone 8plus. I’ve done EVERYTHING and brought it to an apple repair place for them to tell me there’s nothing wrong and for public to tell me there is something wrong with my phone. My suggestion is to switch SIM cards with your husband and that will rule out a phone isssue. Also reach out to your cell phone company and to public so they’re aware of the issue.
10-28-2020 06:13 PM
I've posted about this in the forums several times. This is an ongoing issue with public mobile, and I know 2 other people that constantly have this problem. Public mobile refuses to acknowledge this problem... there must be something that is fundamentally wrong with their network and that they're hiding. Please let me know if you ever get this solved... my hunch is that you won't
10-25-2020 09:15 PM
It rings and the call goes through. Thankfully it didn't happen today. I need to monitor this.
10-25-2020 02:04 PM
@Dolphin1 wrote:
By rebooting the phone do you mean turning it off ? I turn it off for a few minutes at least once a week.
Check both call block and forward and neither of them was on.
Yes, just turning the phone off and then on again. Sometimes software bugs rear their ugly head and disrupt functionality when you least expect it. If there are no obvious issues with the phone, it might be worthwhile asking a moderator to check and perhaps reset the self serve account. I have not had issues with calling for a long time but in the early days I did have my account reset a couple of times to resolve calling issues.
10-25-2020 12:56 AM
I should have asked...what happens when you call your husband ?
10-25-2020 12:30 AM
Hi @Dolphin1 here is an article that might help you fix your issue (if you have an android phone)
https://www.technipages.com/fix-android-phone-call-goes-straight-to-voicemail
10-25-2020 12:00 AM
10-24-2020 11:58 PM
10-24-2020 11:56 PM
The strength was full bars and was not on DND or airplane mode. The first 3 times he called it went straight to voicemail, the 4th time he got through, we tried it one more time and it went to voicemail. It's very strange.
10-24-2020 12:45 PM - edited 10-24-2020 12:47 PM
@Dolphin1 wrote:Is anyone having an issue with calls going straight to voicemail ? I find in the past few days this is happening. We just tested where my husband calls me and it goes straight to voicemail. Any idea why ?
What happens if your husband calls you?
Is your phone on DND or airplane mode?
How many vertical bars do you have?
10-24-2020 12:24 PM - edited 10-24-2020 12:24 PM
With Public Mobile, calls must use 3G, whereas texting & data can use either 3G (WCDMA/HSPA) or 4G (LTE) networks.
When someone calls you, your phone has to switch from LTE to 3G to take the call. If that transition doesn't happen fast enough, or you have poor 3G coverage in your location the incoming call may fall to voicemail.
You can try forcing your phone to 3G all the time, no 4G/LTE mode to see if it helps with incoming calls.
10-24-2020 12:13 PM - edited 10-25-2020 01:20 AM
maybe weather is a factor in your reception
10-24-2020 12:09 PM
I haven’t had this happen although it’s common on other cell providers. If this is happening to you a lot, you should bring this to the attention of a mod for them to look into it for you.
10-24-2020 12:09 PM
Go into the phone settings to make sure "Do not Disturb" hasn't been enabled.
10-24-2020 12:08 PM - edited 10-24-2020 12:09 PM
@Dolphin1 , I just tried calling from one Public Mobile account to another and had no problems. If you have not rebooted the phone in a while, perhaps do a reboot to refresh the connection to the cellular network. See if that makes a difference. Check also the possibility of call blocking or forwarding being set inadvertently.
