Going back to previous plan with same benefits
monakaushal0717
Hi, I recently switched to $55 plan thinking that I might use lot of data when I am out. But out of 20 GB not evey 1 GB is utilized still.
I want to go back to $15 plan with unlimited Canada wide call. Please help. 🙏
DDM69
Disregard the answer from Alexandf.  Of course you can switch back to your old plan.  Just follow the steps mentioned by the other experienced community members.  Good luck! 😊
hairbag1
You can change back to the $15 plan if you want. I suggest you select Change at next Renewal.
edit...Log in to your account / Plan and Add-ons / click Change My Plan. Use the little yellow arrow to scroll to the plan you want...Then click Change plan on next renewal date.
@monakaushal0717   you can definitely schedule a plan change for next cycle
Unfortunately, PM is prepaid provider and won't be able to refund or do partial refund with your current cycle even you didn't use much of it.
dust2dust
@monakaushal0717- You can totally change back. I suggest setting up for your next renewal.
Alexandf
@monakaushal0717
check plan online
you can't changed  open ticket with PM support and ask them to fix it,
 At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
