08-01-2025
10:48 AM
08-01-2025
06:12 PM
computergeek541
Last many years, PM would give gifts in data, LD, etc. At that time, when you purchased or was gifts, it didn't run out, you used as you went. I had loads, now I can't find them or the page to see your balance. Seems to me I should still have plenty of data and LD. Thank you
08-01-2025 11:02 AM
I found it! Thank you. However, I have nothing except what comes with the monthly plan. 🤔
08-01-2025 11:01 AM
ALL your bonuses, gifts from PM should be on your account Unless you used them up. Particular data could be used without your awareness if you are on-line all the time; some apps and system uses your data for constant updates, checks, etc.
Even non-expiring add-ons should be there... Only data add-on has expiration date (as I am aware).
08-01-2025 10:52 AM
hi @Ella2025
they are there. Login My Account or the app, click Usage Breakdown under the usage odometer on the main page and you will see them listed there
you will see something like this:
