11-02-2023 09:03 AM
Hi @CS_Agent,
I’m currently abroad and had to a change phone without sim card. I need to get my current phone number in an eSim on this new phone.
I cannot do almost anything without my phone number. Could you please help me asap?
Thank you
Service
11-02-2023 09:07 AM - edited 11-02-2023 09:08 AM
You can purchase a eSIM from PM by downloading the app on the intended device, logging into your account and going to the subscription and add-on’s tab, and then scrolling down and selecting “Shop SIM Card Now”.
Just know that PM doesn’t work outside of Canada and the US (with a Can-US plan or roaming add-on) so despite adding the eSIM to your phone, you might not have service depending on where you are abroad.
11-02-2023 09:06 AM
HI @AnhThu
first, you are in US with a US roaming plan? If not, there is no service in other countries (or there won't be service in US without roaming add-on or roaming plan), you can wait till you are back in Canada to do it
But if you still want to try, can you download your PM app on your phone? Download Pm app, Subscription, scroll down to bottom for Shop sim card and buy esim there and you can setup esim on the phone
