OnePlus 8 Pro 5G
Bhavin25
Hi!
Does anyone with this phone get 5G working with Public Mobile?
Have you installed any and all OS updates?
But it kind of doesn't matter. It's 5G speed, not really exactly 5G network. You can get the same speed when connected to the 4G LTE network like you have.
Bhavin25
No it's not selectable and I can't figure out why.
@Bhavin25
The Oneplus 8 Pro should automatically switch from 3G-4G/LTE-5G if you have 5G coverage in your area. It should also indicate 5G on the phone.
Refer to 5G map:
https://www.publicmobile.ca/en/on/coverage
HALIMACS
@Bhavin25
Does 5G display as a selectable option in the network connection settings?
